It is currently Mon Aug 11, 2025 11:15 pm
PostPosted: Sat Sep 26, 2020 4:01 am
Hi all
I'm rebuilding a 1981 CR125 engine, but cannot source the 15mm thrust washer that goes on the end of the counter shaft, after the idle gear. Any ideas where I might find one, or an alternative? The Honda part number is 90457700305.
cheers
PostPosted: Mon Oct 05, 2020 6:20 pm
Many dealers can do a part search that checks the inventory of other Honda dealers. If the washer is no more than .5mm thick, about any will work as long as the outer circumference is not to big. Once the bottom end is back together and you have a tiny bit of side to side play in the shaft it should be fine.
