It is currently Sat Jul 05, 2025 2:53 pm
 Post subject: 77 pipe on 75 CR125?
PostPosted: Sun Dec 11, 2005 5:39 pm
:arrow: Has anyone put a 77 pipe on a 75 CR125? Did it fit okay? I understand that the exhaust manifold will be a little sloppy, but does the body of the pipe fit okay on the bike?
Thx.
PostPosted: Mon Dec 12, 2005 10:35 am
The 1977 CR125 pipe will bolt right up to your 1975 just make sure you use the 77 exhaust manifold which will also bolt right right up. No sloppy fit. As for the body of the pipe nothing changes, get a good pipe hanger & bolt it up!
A little tip..I use a large stainless hose clamp & slip it through the bottom of the frame & around the pipe, tighten it & you will have no play what so ever.
