It is currently Sat Aug 02, 2025 1:32 am
 Post subject: Piston id needed
PostPosted: Sat Apr 08, 2006 4:35 pm
Hello all
Is there anyone who may be able to id this Genuine Honda part no for a piston
13101-466-000
Bike model and year would be great
Kind Regards
conn4000
PostPosted: Sat Apr 08, 2006 6:45 pm
The middle three positions identify this as a CR125RA which I think is a 1980 model. (The first five positions identify the type of part and the last three identify subsequent modifications. This is the first iteration, later ones might be XXXXX-XXX-710 etc.) If you go to http://www.cmsnl.com you can download a complete list of model codes. BTW the way later models can still use the same part and the older model code will be used i.e. many parts on the 1978 through 1980 CR250R share the model code 430 because they were used on the 1978 first.
 Post subject: OEM 1980 CR125 PISTONS
PostPosted: Sun Apr 09, 2006 4:36 pm
Thanks Red rocket, yep looks like ive got a box of six to get rid of with loads of oem rings.
also have lots more in a box of mixed cr250 and cr125 bits and bobs ill get a list together and see if anyone wants them
may trade for a dg head or fox 17.5 shox for the lot
any takers????
