It is currently Mon Jul 07, 2025 2:45 am
Does your elsinore have a floppy kickstarter?
Yes 75%  75%  [ 6 ]
No 25%  25%  [ 2 ]
Total votes : 8
PostPosted: Wed Jan 03, 2007 3:32 pm
Does anyone know how to fix for the infamous floppy kickstarter on the elsinores? I have a 1976 MR175 with this problem, and i just bungeed the kickstarter against the frame and push start it, but i would like to fix it correctly. Is it a simple thing of replacing the kickstarter pivot bolt, or do i need to replace the whole thing?
Thanks in advance
PostPosted: Fri Jan 05, 2007 3:08 pm
If it is just a loose kickstarter arm on the shaft, might try new bolt. But if the shaft swings, too, the problem will be inside the case. Make sure the spring is on correctly and the pawls are in good shape. I put mine in wrong once and knew it immediately.
PostPosted: Fri Jan 05, 2007 5:50 pm
Depends on what you mean floppy......kick starter don't work at all, internal problem, spring has jumped off inside or maybe worse problems.
Just flops around but still works(starts engine) and don't stay put is what I'm thinking you mean.
Mine was because the bolt hole that the kick starter pivots on was wallowed out, fixed that problem by making a brass sleeve insert, got some brass tubing fromt the hardware store that the bolt would fit into snuggly and then pressed that into the kickstarter, cleaned the spring and ball and works fine(for now)
Garry Mainer
#33m (retired)
Honda Cr250r 1980
Honda Cr250r 1980
Yamaha TY250C 1976
Arctic Cat 650 H1 2007
 Post subject: flopper fix #2
PostPosted: Tue Jan 09, 2007 11:08 am
The usual problem is the detent mechanism.
There is a spring, ball and a concave indentation/hole. The hole gets worn and the ball just doesn't hold the kicker in place anymore. You can see how the hole is elliptical or the walls are rounded.
The fix is to weld the edge of the hole and re-shape it with a grinder.
Then make sure the ball and spring are in place and providing good tension. The ball can get a flat spot worn in it.
New ball, pull the spring a little and re-shape the hole and your kicker will be good as new!
Go4Ducks2 has a good idea of there's a problem with the bolt!
PostPosted: Sun Feb 18, 2007 2:05 pm
To all:
We repair all kickstarters.
Proformance Cycle
mailto:proformance58@cs.com
Not trying to spam anyone just offering help to all to keep the "OLD" stuff going!
Proformance Cycle
c/o Lee Curry
58 Wyoming Ave.
Wyoming, PA. 18644
570-693-5811
Users browsing this forum: Google [Bot] and 40 guests
