It is currently Sun Jul 06, 2025 2:18 pm
 Post subject: 1980 front forks
PostPosted: Sun Jan 28, 2007 2:11 am
Hello CR friends. I'm putting together a cool looking 1980 cr250r to race in the EVO and was thinking of up gradeing my front forks. I'm 200lbs and was wondering if the 81 cr450r forks are any better then the ones that came with the 80 250. are the sizes the same? thanks Scott
2-1973 cr250m
2-1980 cr250r
1979 cr125r
1979 yz400f
1971 mini trail 70
2005 VTX 1300c
PostPosted: Sun Jan 28, 2007 6:39 am
See Redrocket's response to my post below regarding "Fork Upgrade for '79 CR250." The '81s are 41mm, which I suspect are larger than those on an '80 but I'm not sure.
PostPosted: Sun Jan 28, 2007 11:42 am
I upgraded to the 81 forks on my other 80 250,which are 41mm, had a tough time finding them and then even harder time finding a tree. You'll probably have better luck with the 82-83 which are 43mm.
Got mine off ebay, seems like the 1980 stuff has slowed down here of late.
Garry Mainer
#33m (retired)
Honda Cr250r 1980
Honda Cr250r 1980
Yamaha TY250C 1976
Arctic Cat 650 H1 2007
PostPosted: Sun Jan 28, 2007 2:11 pm
I would go with the 43mm Showas from 1983. You are going to need a stiffer fork spring over stock, and some re-valving. Race Tech might be able to do this for the older forks, but I know they can do it for the 1983s...
