Sam427 wrote:
I wouldn't recommend removing the bridge, it won't run long like that. Basically on the bridge, Honda says put a radius that dips in at the midpoint of the bridge about .004" and feathers out at the top and bottom of the port. I have done a bunch of work on those cylinders, and I have seen everything from stock to wild on porting, lets just say that less is more. I would love to help you, but I don't give away my trade secrets on the engines I build. Good Luck!
Thanks Sam,yep intended to do the exhaust bridge as you had recommended anyway, I was just curious about removing the bridge,don't worry I wasn't angling for any trade secrets just some basic's thats all,unfortunatly your on another continent to me so sending it for some work is abit of a pain,I like to do as much as I can myself (well everything actually)but don't want make a mess of it so just general tiding up it is,
thanks for taking time to reply though,just been told my barrel is ready so should have it back in a couple of days.
