It is currently Tue Jun 17, 2025 8:08 pm
 Post subject: KD 80 power problem
PostPosted: Thu May 03, 2007 3:23 am
Hi everyone!
i have a KD80, with issues
it starts and idles great, but as soon as you twist the throttle quickly
she sounds like she's just sucking air (no acceleration)
i inspected the carb, when i rev (quick) it, i can see a vapor cloud
appear outside the venturi, along with no acceleration
carb seems to be swimming with fuel, so i dont think thats a problem
i can accelerate slowly, and the rpm's go up no problems
breaks up when its high a bit
i can ride it, but it needs a load of rev's and it doesn't have much torque
could this be that the timing is too advanced?
whats the best way to do it? from the points??
PostPosted: Thu May 03, 2007 12:05 pm
I've had similar symptons when the main needle gets loose. Clip or plate that holds it in place comes loose or doesn't get put back right.
Pretty easy to check. Just remove the slide and see if the needle moves up and down in it. You shouldn't have more then a few mils of movement.
Rick
PostPosted: Thu May 03, 2007 2:36 pm
cheers!, i will check that!
PostPosted: Sat May 05, 2007 2:34 am
carb seems to be fine :cry:
PostPosted: Sat May 05, 2007 10:53 am
Is it a reed valve engine? Other then carb issues that is probably the most hopeful thing it could be wrong w/o a major rebuild. It could also explain the back flow coming out the carb.
Doesn't take much, just a piece of crud holding the reed off its seat, to make trouble. They do break but kind of rarely.
Rick
PostPosted: Sat May 05, 2007 5:38 pm
i believe its rotary valve
PostPosted: Sun May 06, 2007 12:13 am
i retarded the points, seems to run alot better, still a bit saggy, nothin a top end rebuild wont fix i guess :lol:
 Post subject: Re: KD 80 power problem
PostPosted: Thu Aug 14, 2008 8:59 pm
I bought a used bike with a similar problem once. The piston had bee put in backwards. The arrow that should be pointed forward was pointed backwards toward the intake.
PostPosted: Tue Nov 04, 2008 8:24 pm
Check the intake boot between carb and cylinder, if it is leaking it can cause problems...
