It is currently Mon Jul 07, 2025 7:41 pm
 Post subject: 73-74 CR250 timing help
PostPosted: Sun Nov 25, 2007 7:59 pm
I have a CR250m (just put together) that I'm checking the timing on and need some advice/help. It has the original ignition and I have a dial indicator setup. I need to know how to set up a test light???. Or what else can you use?? When I tried to set one up ( test light) with a 6volt battery and a bulb I could'nt get it to work, It stayed on all the time when I turned the crankshaft even when the points seperated. I hooked a battery up with a bulb in series and connected it to the wire coming out of the points/rotor and the grounded the other end to the frame. As I said the light came on and stayed on. Was it hooked up right?
PS the bike seem to run pretty good so I know the points are operating but I just want to double check the timing before I ride it in anger
thanks
PostPosted: Mon Nov 26, 2007 9:26 pm
It's been many years since I did a CR, but I think you should disconnect any wires going to the points,ie condencer etc and try it again like you did.My MR 250 is not done the same as a CR,you just set the points to the proper gap and your done
PostPosted: Tue Nov 27, 2007 1:19 pm
Long ago I would check the timing of my '73 XL350 using a small transitor radio. Don't know if those are made any more. I would slowly turn the crank with the radio not tuned to a station. When you hear a crack (static noise) that means the points sparked and the timing marks should line up at this point. A piece of cellophane in the points with steady pressure will give pretty much the same results. This won't tell you if the advance is working of course. Good luck....Van
1980 Honda CR125R
PostPosted: Tue Nov 27, 2007 4:29 pm
thanks for the replies, I got it worked out. I saw an article where a guy suggested using a cigarette paper between the points to tell when they opened. So off to the store for some and they worked!
