It is currently Fri Aug 15, 2025 2:54 pm
PostPosted: Mon Jan 21, 2008 11:57 am
I'm working on rebuilding a 1980 CR250 engine from a mini sprint car, and converting it for use in a Bonneville salt flats race car.
The first thought I have is doing away with the close ratio gearing. Is it possible to swap gears from an MT/MR from the same period?
PostPosted: Mon Jan 21, 2008 6:41 pm
there is no swap that i know of.the 78-80 gearboxes are completely different than the 73-76 cr,mr,mt transmissions.i dont think any parts will interchange.i have a 75 model cr250m1 that has the 5th gear mainshaft and countershaft gears from a mt250 in it and it has truly eye watering top end.
PostPosted: Mon Jan 28, 2008 1:29 pm
Bummer. Anyone know the tranny ratios for this motor, and max RPM? I need some numbers to tell the guy if the motor will make the speeds he needs or not.
PostPosted: Thu Jan 31, 2008 8:17 am
if its anything like my 79 model.i am guessing about 7500,maybe 8k or so.these motors dont have a lot of over rev.my 75 model kills it in revs.it will do 8500 or even 9k.it winds like a hot 125.
PostPosted: Sat Feb 02, 2008 7:59 pm
Just going by the Honda advertising of the day 37BHP/7,000RPM and out of the owners manual Primary reduction 3.250 gear ratio 1/ 1.900 2/1.591 3/1.240 4/ 1.000 5/0.839 .Thanks Mark Birkett
Couple of CR`s
