It is currently Sat Jun 21, 2025 1:37 am
 Post subject: 78 elsinore 250
PostPosted: Mon Jan 21, 2008 3:38 pm
hello! I am new in the forum and just buy a 78 elsinore 250 with broken rod and not very good condition but i think is very good base for my restoration projet.The bigest problem is that i am in Spain and i have to arrange the shiping ,the bike is in philadelphia PA .I am plannig to fly there and making it parts to get it in boxes.
Are the bolts and nuts inches or metric sistem? Is there any body around Philadelphia who wants to help me?
The guy who sold me the bike gave me two weeks to pick up the bike .Any sugestion?
I´m crazy to beging the projet,that seems to be easier with this great forum.Sorry for my english.Thanking you in advance :Daniel
PD.we dont have elsinores in Spain,only Bultacos,Montesas,ossas,.... etc.If you need help........
74 cota 25
74 cota 123
76 bultaco matador
88 kx 125
07 wr 450
 Post subject: Re: 78 elsinore 250
PostPosted: Mon Jan 21, 2008 9:19 pm
Everything is metric on the bike. Good luck with it. Thank goodness for internet swap meets and auctions when it comes to restoring these old bikes.
PostPosted: Tue Feb 05, 2008 5:33 pm
Hi again
I finally flew to philadelphia and took the bike with me in 3 bagages,its finally at home ready to work on it.I`m gona need a lot of information:
-wich fenders and seat cover are the best?
-are the oem side panels painted?
-is possible to repair oem shocks?
-i need all the air box parts,like the rubber tube,air filter frame,etc....everything except the case,the bike has a K&N installed
I hope you can help me.Thank you.Daniel
PostPosted: Tue Feb 05, 2008 6:17 pm
Some pics:
http://www.kodakgallery.com/BrowsePhoto ... 075&page=1
PostPosted: Tue Feb 05, 2008 6:33 pm
some pics
http://www.kodakgallery.com/I.jsp?c=c79 ... &y=-qby54l
PostPosted: Wed Feb 06, 2008 7:18 am
I've heard VMX and Vintage Iron plastics are good. I bought a seat foam and cover from AMS Racing and was very pleased. I believe the shocks are rebuildable.
PostPosted: Wed Feb 06, 2008 10:18 pm
danielsanchez wrote:
Hi again
[url]
http://vmxracing.com/[/url] - Replica fenders and side panels. The OEM side panels were painted, don't bother with the replicas. http://www.mxm.co.uk/ - Replica seat cover. No it is not possible to repair OEM shocks and they are junk. Look for Fox air shox on eBay or buy Works Performance, Falcon etc. The length is 17.5". I'll sell you a complete air box, but it'll take a week or so to pull all the parts together. Take advantage of the weak US dollar...
PostPosted: Thu Feb 07, 2008 1:13 pm
I have a set of fox air shox they need a rebuild I am willing to part with them for 500 what I paid for them when I bought them. I got them from a guy who had them on a cr I was gonna use them on my xl but decided not to cause im never going to race it so why be ahrma legal. If your intersted let me know I will get you some pictures
PostPosted: Tue Feb 12, 2008 8:27 am
thanke you all
I can not afford to buy fox shocks by the moment,but i am interested in the air box if it is complete and would like to know the price.
PostPosted: Thu Feb 14, 2008 4:08 pm
Daniel,
I will put together a document for you in the next couple of weeks describing the rebuild procedure that I have used on numerous sets of stock shocks. One of the reasons that the stock shocks received bad reviews was because the nitrogen leaked out of them almost right out of the factory and there was no way to recharge them. You can buy 40mm x 12.5mm Race-Tech YZ80 shock bearing heads and use them are replacements for the originals. I have seen them around for about $45 each. Be sure that you have decent shock rods before making the investment. Compression and rebound damping are adjustable with shims, much like any present-day rebuildable unit. You can get your spare shims from other Showa shock cadavers including CR and XR dual shock models. This pretty much leaves the quality of the ride up to your patience with experimentation, and multiple test rides for evaluation.
Adding a Schrader valve for nitrogin charge is not difficult. Adding a remote reservior is fairly easy.
Removal of the end bearing cap without damaging it is the only slightly tricky part. I will show you how to part it from the shock using a metal lathe and a brass drift. If you don't have access to a metal lathe there other, not so delicate ways of removal. Don't start cutting on the shocks until you have relieved any residual nitrogen pressure by drilling a very small hole in the location where the
Schrader valve will be. I will provide you with approximate dimensions later.
The stock shocks are cool once you're comfortable working with them and they hold more oil than my Ohlins. That makes them even cooler.
1978 CR250R
1980 CR250R
1980 ME360
1986 CR250R
PostPosted: Wed Feb 20, 2008 2:30 pm
Daniel:
Hola como estás?
I have a CR250 79, and you know what else? A Cappra 360.
I wonder how you took the bike in luggages, because I was interested in buying or selling a bike fron/to US.
My e-mail is: mailto:estebancasarino@cmm.com.py could you contact me on this??
Thank´s.
XR75, CR125, CR250, Cappra 360, Sherpa 215
PostPosted: Wed Feb 20, 2008 6:45 pm
Hey Moto Recon what is your emaill? I am in AZ too and may want a set of 79 CR250 shox redone. Were they oil filled or just gas originally?
PostPosted: Thu Feb 21, 2008 9:51 am
Elsinorestuff,
The original 78/79 Showas were emulshion shocks, oil and gas, no bladder, or internal floating piston. When you take an original seal out of the bearing head, you'll understand why the gas escaped, especially if stored with the shock rods up. The fit was too loose, maybe 'cause the seal shrank.
When you open the shock, and if you see a bunch of rubber chunks inside, it's a former rebound ring once located between the bearing head and the piston that became hardened and pulverized. It happened on some shocks, not on others, the rings remained soft. I just leave them out completely. The only way that these shocks will top-out is if you forgot to put the piston and/or the fluid in. I have been charging with 125 lbs. of nitrogen.
I sent you an email.
Bob
1978 CR250R
1980 CR250R
1980 ME360
1986 CR250R
PostPosted: Thu Feb 21, 2008 12:43 pm
Moto recon:
Can I understand by what you explained that stock shocks will leak without use?
I have an almost no use 79 cr 250, and the shocks were leaking and the paint was scratch by the springs. By looking at the bike I could tell why the shocks look use and the bike doesn´t.
the bike is the march 2007 bike of the month ( esteban casarino ) take a look.
PostPosted: Thu Feb 21, 2008 1:35 pm
Hello!
The shocks were built under nitrogen gas pressure and I bough several 79 CR250rs new and most of the gas charge had already leaked out before leaving the showroom floor.
1978 CR250R
1980 CR250R
1980 ME360
1986 CR250R
