It is currently Sun Aug 17, 2025 5:23 am
 Post subject: mikuni carb advice
PostPosted: Sat Mar 01, 2008 9:34 am
I have an '80 cr 125 the stock kehien carb was wore out it would never clean out no matter what I did to it. I replaced it with a 34mm Mikuni in the middle and on top it's still fast the problem is when you get out of the throttle it bogs real bad I,m thinking that the float seetings are off can I change them or if i shim the floats with some small washers would this help the problem.
 Post subject: Re: mikuni carb advice
PostPosted: Sat Mar 01, 2008 9:49 am
You set the float by bending the small tab that pushes on the float valve. No shims needed. You may have a pilot jet that is too small causing a lean situation. If it is the other way and is rich it will blubber and act loaded up down low.
PostPosted: Sat Mar 01, 2008 6:21 pm
I just replaced my Kiehen with a 34 mikuni on my 1980 CR125 as well. It has a 260 main jet. just wondering what pilot jet works best. I haven't had the chance to ride the bike, I'm waiting to get my forks back from the suspension shop next week.
Terry Moody #48f
3x 74 Honda CR250M Elsinore
74 Honda XR75
73 Honda QA50
78 Yamaha YZ125E
78 Yamaha YZ250E
78 Yamaha YZ400E
79 Kawasaki KX250
79 Honda CR250R
79 Suzuki RM400
80 Honda CR125
2x 83 Honda CR480R
98 Kawasaki KX250
