It is currently Sat Jun 21, 2025 1:10 am
 Post subject: 78 CR250 Head Gasket
PostPosted: Sat Apr 19, 2008 11:15 am
Hello all. I bought a new head gasket for my 78 CR250. Do I just put it on as is as it is a copper gasket? Or are you supposed to put something on it when you install it?
 Post subject: Re: 78 CR250 Head Gasket
PostPosted: Sat Apr 19, 2008 1:15 pm
As is, will be fine.
PostPosted: Thu May 01, 2008 10:54 pm
What torque ratings should i tighten the head bolts to?
Thanks!
PostPosted: Fri May 02, 2008 9:21 am
Go the Reference section and download the manual....
PostPosted: Sun May 04, 2008 9:27 am
It says in there to torque the cylinder nuts to 28-35 lb ft but I cant see anywhere where it tells you what to torque the head nuts too? Can you please let me know as I have been wanting to change my head gasket and dont want to until I know the proper torque....
PostPosted: Sun May 04, 2008 10:13 am
17,4 - 20,9 lb ft
PostPosted: Sun May 04, 2008 11:20 am
9 lb ft? What is the "17, 4-20" mean in your post?
PostPosted: Sun May 04, 2008 12:14 pm
17,4 - 20,9 lb ft means 17.4 to 20.9 lb-ft
PostPosted: Sun May 04, 2008 1:15 pm
Thank You!!
PostPosted: Sun May 04, 2008 3:43 pm
Page 66 - Cylinder Head - 14.5 to 16.6 ft lbs. Snug them down hand-tight and then torque using a criss-cross pattern.
PostPosted: Sun May 04, 2008 4:02 pm
Uh Oh..... I already did it earlier this afternoon and torqued to 20 lbs ft... I took it for a ride and it seemed fine... what problems is this going to cause me over torquing them like this? And yes I did the criss cross pattern when tightening them....
PostPosted: Sun May 04, 2008 5:23 pm
Just ride it it will be fine.
You obviously haven't stripped the threads or distorted anything so you have no worries.
PostPosted: Mon May 05, 2008 12:01 pm
sorry, in europe we use ","
for you it`s 17.4 - 20.9 lb ft
