It is currently Thu Aug 14, 2025 4:46 pm
PostPosted: Sat May 24, 2008 2:29 pm
will it work?
1983 480('82 motor). basically stock except '87 front end revalved by white bros, front disc, dg silencer, tag oversized bar
1987 cr250. pro circuit works pipe and 304 silencer, v force 3, ohlins rear shock, '89 front end, tag oversized bar
PostPosted: Sun May 25, 2008 11:20 am
i was also wondering if you can use the cdi and coil from the 250? they look the same, dont have the 480 yet so just thought id ask a few questions while i wait on ups.
PostPosted: Mon May 26, 2008 11:38 am
it will fit.
you can use the 250 coil but the cdi is another.
the 480 will run with the 250 cdi but not realy good.
PostPosted: Tue May 27, 2008 10:03 am
thanks for the info, i guess ill be looking for a 480 cdi
PostPosted: Fri May 30, 2008 9:57 am
well there is one roadblock ive run into, and that is you have to cut out the lower radiator mount.
PostPosted: Wed Jun 04, 2008 9:57 am
gas tank mount is different too, you have to cut off the mount, then fabricate brackets to secure the gas tank. i have everything in now and it looks good, let you know how the test ride goes....
PostPosted: Wed Jun 04, 2008 10:34 pm
OK, I'll ask. Why?
