It is currently Thu Jul 03, 2025 5:28 am
PostPosted: Sun May 02, 2004 11:47 am
Anybody know of someone that can trick out stock 79 CR forks? What were some of the kits for these back in the day (Terry Cable is all I can think of.) Does Race Tech make gold valves for these forks?
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Sun May 02, 2004 6:58 pm
I have heard that drilling a 1mm hole in the damping rod and using lighter weight oil makes these forks better, as does using DG or Pro-tech air caps. However most people replace the forks with a 43mm Showa front-end from a 1983 CR480R. Race Tech does parts for these newer forks. Some lucky folks have found 44mm Fox Factory forks or 38mm Simons...
PostPosted: Sun May 02, 2004 11:43 pm
Michael,
You don't really have to be lucky, just willing to pay through the nose. :shock:
1988 Honda CR250RJ
1983 Honda CR480
1979 Honda CR250RZ
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
