It is currently Fri Jul 04, 2025 7:42 am
 Post subject: Hello
PostPosted: Tue May 04, 2004 11:11 pm
Hi. I have recently acquired a MR175. I do not know the year. I am thinking it is a '76, but not sure. I am need of some information on her. I need to know what size chain she needs and the ft/lb ratings for the head. I also need to know where I can find misc. parts. I need a perch for the clutch lever and a clutch cable.
Scott
PostPosted: Wed May 05, 2004 12:31 am
http://100megsfree4.com/honda/ This might help confirm the year.
PostPosted: Wed May 05, 2004 10:24 am
Thanks. I just about had it to '76 and that site confirmed it for me.
What about a fuel mix. Will the standard 32:1 work?
PostPosted: Wed May 05, 2004 1:20 pm
The pre-mix ratio question comes up regularly. Buy a good oil - Bel-Ray, Maxima, Spectro or whatever and mix it to their recommendations. I would go 32:1 unless you chose Bel-Ray MC-1 which should be higher i.e. 50:1. Don't get obsessed over the influence of ratio on jetting...you are only playing with about 1/3 of a main jet size or one clip position on the needle. Altitude and temperature will have much more of an affect.
PostPosted: Wed May 05, 2004 4:31 pm
I was kind of thinking same way. How about the spark plug gap. I have it at .032 now. I am getting ready to try and kick this beast over and I want to make sure I have everything squared away. I have tried using the "spec " section here but I cannot get it to work.
Users browsing this forum: Majestic-12 [Bot] and 37 guests
