It is currently Sat Jul 26, 2025 6:31 am
PostPosted: Tue Oct 14, 2008 8:13 pm
hi
can anyone help me with jetting specs for the 38mm mikuni carb for my 1973 cr250m.
it also has a read valve set up from mx360 yamaha fitted.
cheers
jim
Jim Garvey
1x honda cr250m 1973 in bits
1x yetman triumph dirttracker
PostPosted: Tue Oct 14, 2008 9:56 pm
I pulled a 38mm Mikuni off a well-sorted 74 recently and jotted down the jetting specs. Main 320; pilot 60; Slide 2.5; Jet needle 6DP7 middle groove.
The bike had a DG head, race pipe, and was ported and it ran really well.
And the bike is for for sale with a stock head and with a stock Keihin carb if anybody needs an Elsinore.
PostPosted: Wed Oct 15, 2008 8:17 pm
mrmikkelsen: out of curiousity and the never ending quest for knowledge to make assorted parts sometimes work correctly, did you notice what needle jet was in the carb body??
Thanks, -Mitch
PostPosted: Wed Oct 15, 2008 9:44 pm
Aargh! No, I sure didn't look, or at least I didn't write it down. Given time, I'll be back into the bike again, but that won't be right away. Hopefully somebody else can do better?
PostPosted: Fri Oct 17, 2008 12:35 am
Here is what I use and I am in California. My 73 CR250 has a 38mm Mikuni Roundslide. 300 mj, 25p, q-6 nj, 6DH7 #3 N, 2.5 slide.
3rd over on the top end & a circle -F pipe at the time.
frohrs1
PostPosted: Mon Oct 20, 2008 12:52 am
thanks guys for the help will report back with results.
also might post a progress pic
cheers
jim
Jim Garvey
