It is currently Fri Aug 15, 2025 7:35 pm
PostPosted: Fri Jan 02, 2009 4:26 am
HI
what other kick starters will fit the cr250m as my CF pipe is too close to use cant get a good kick when starting the engine.need something that turns out a bit more to give me clearance
thanks
jim
Jim Garvey
1x honda cr250m 1973 in bits
1x yetman triumph dirttracker
PostPosted: Fri Jan 02, 2009 8:08 pm
The MR250 kickstarter should fit, as the shaft is the same as the early CR250M's. I have a picture of both bikes side by side and it looks to me like the MR250 kick arm may be an inch or so shorter than the CR250M arm, but I don't know if that will help you or make things worse.
I think if it were me, I'd try bending my existing arm out a bit more. I'd obviously do it off the bike, and with the arm bend point heated cherry red.
There's a CR250M kicker on eBay right now, and every now and then someone parts out an MR250, although they're fairly rare.
