It is currently Fri Jun 20, 2025 2:27 pm
 Post subject: CR 480 carb boot/flange
PostPosted: Wed Mar 04, 2009 6:34 am
Hi,
I'm trying to put together a CR480 engine from spare parts and the only things I haven't been able to locate are some intake bits.
I read somewhere that the reed valve from a 1987 CR250R (and maybe other years?) will fit, so that's one problem solved. But I obviously need something to attach the carb to the reed cage, and I can't find any boots anywhere.
What are my options here? Will they fit from some other model? I don't care much about the angles or anything, I'll be happy as long as I can mount a carb.
I was thinking of using a 38mm Mikuni flatslide carb instead of the original Keihin, because I have a couple of those laying around and I'm more familiar with them.
I guess it wouldn't be that hard to fabricate an adapter/spacer plate but I'd really prefer something that will bolt straight on.
Any tips? Thanks in advance!
PostPosted: Wed Mar 04, 2009 2:17 pm
you can use a reedcage from a cr250 78-01. and the boot from a cr250/450/480 81-83.
PostPosted: Wed Mar 04, 2009 4:06 pm
Thanks for the answer, that helps :)
Are the boots still available new anywhere or should I be looking for used ones on ebay? I usually do my shopping from dennis kirk but they don't seem to have it, any tips where I might find a boot?
PostPosted: Wed Mar 04, 2009 8:26 pm
Keep your eyes open on ebay, the boot is now a discontinued part but i have seen some new reed valves for sale recently.
Try http://www.motocrossworld.com/site/
They have big stocks of old Honda parts.
Users browsing this forum: No registered users and 48 guests
