It is currently Fri Jul 04, 2025 4:13 pm
 Post subject: what weight of oil?
PostPosted: Thu May 27, 2004 7:08 pm
i have a 78 cr250 and i was wondering what is the proper weight of oil to use when doing an oil change? just a 5w30 or?
thanks!
PostPosted: Thu May 27, 2004 7:11 pm
sorry also what is the correct amount to put back in..... thanks
PostPosted: Fri May 28, 2004 1:55 pm
If you just drain the transmission in place, put 500 cc back in. If you are doing a re-build put 750 cc in. There is a cross-head/hex oil level screw on the right-hand side of the motor , but I do not use this method to check there is enough oil in the transmission. I use motorcycle-specific Bel-Ray SAE80 weight oil rather than automotive products to avoid any friction modifiers that will hurt performance of the clutch.
