It is currently Sun Jul 27, 2025 9:05 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Sat May 09, 2009 7:40 pm
As Mentioned above, i really need this diagram, doe anyone have one please?
______________________________________________________________________________________________________
74' Honda CR125
75' Honda TL250
06' Baja Motorsports MB165
PostPosted: Sun May 10, 2009 2:07 pm
I sure it may be in my owners manuel for a 1974 CR125. I will check for you. It's pretty basic though.
frohrs1
PostPosted: Sun May 10, 2009 2:30 pm
Cool, thanks alot
74' Honda CR125
75' Honda TL250
PostPosted: Tue May 12, 2009 9:00 am
I have it. It's 1 page in back of the 1974 CR125 original manuel. Would you like me to make a copy of it & mail it to you?
frohrs
PostPosted: Thu May 14, 2009 5:24 am
yeah please, id really appreciate it! motomandd(@)gmail.com
74' Honda CR125
75' Honda TL250
PostPosted: Thu May 14, 2009 6:05 am
Here it is:
PostPosted: Thu May 14, 2009 12:26 pm
That can't be it... ive only got 2 wires coming out of the engine, a yellow one and a black with yellow line on it...
Thanks anyway
74' Honda CR125
75' Honda TL250
PostPosted: Thu May 14, 2009 4:09 pm
No problem - glad to help. I'm sure Honda service manuals are wrong sometimes, and my own CR125M (bought new in '74, and identical to the diagram in all respects) must be a fluke.
PostPosted: Fri May 15, 2009 9:35 am
Thanks anyway
sounds like you have the wrong ignition in it. :(
PostPosted: Fri May 15, 2009 5:07 pm
no, its never been opened, and ive had the thing forever
74' Honda CR125
75' Honda TL250
PostPosted: Fri May 15, 2009 6:49 pm
Agreed - that's certainly a much more likely explanation than an incorrect factory diagram.
I've got three complete ignitions here (two '74's, and one '75) that are identical to the diagram I posted.
P.S. Below is a picture of a '74 CR125M stator assembly. Check out the black/red wire coming from the far end of the left coil, and the green and red/white wires coming from the right coil.
PostPosted: Fri May 15, 2009 9:05 pm
I have the same diagram as Ray. That's listed in the original manuel for the CR125's.
frohrs1
PostPosted: Sat May 16, 2009 8:32 am
Here's another wiring diagram, definitely not for a 1974 Honda CR125:
I've got two MR175 ignitions here that match this diagram.
PostPosted: Sun May 17, 2009 8:47 am
hmm strange, in the cehicle registration it says cr125, and the engine hasnt been taken apart.... i DO have mr175 engines here, so unless someone modified it without my knowledge, its wrong.
im going to put the other magneto in and try that, thanks for all your help guys!
P.S. does this subforum also include TLs? i got one but am not sure it goes here for discussion...
74' Honda CR125
75' Honda TL250
PostPosted: Wed May 20, 2009 11:23 am
Is there a serial # on the engine cases? Left hand side above the ignition cover?
frohrs1
