It is currently Wed Jul 30, 2025 1:38 am
PostPosted: Thu Jun 18, 2009 7:18 pm
I 've given up on my stock carb no matter what i do it floods all the time and spews gas out the air intake.
Is their a replacement or something of another bike that will fit?
PostPosted: Thu Jun 18, 2009 7:28 pm
I think the Mikuni VM30 (30mm) Round Slide carb will fit. But check the deminisions first.
PostPosted: Fri Jun 19, 2009 8:48 am
The closest Mikuni I found was the VM27.7, which is 5mm shorter but otherwise the same as the 28mm Keihin.
For what it's worth - it took a while, but I finally managed to find some eBay 28mm Keihins that hadn't been drilled out, packed solid with dirt, or wailed on by impact drivers. When the carb is set up right, it really works quite well. The MR175, '74-'76 MT250, and '77-'84 FL250 all use the same basic carb, with slightly different jetting and needles.
Here's an MR175 carb auction, from a seller I've had very good dealings with:
http://cgi.ebay.com/ebaymotors/HONDA-MR ... ccessories
PostPosted: Sat Jun 20, 2009 8:16 am
Here's what i got on mine ;) It's a nice carb, and its cheap... if i could ever get the bike to run :lol:
http://scootrs.com/moreinfo.cfm?Product_ID=701
-----1975 Honda MR175--------------------------------------1972 Suzuki T500 Titan------------------2003 Honda 250 Rebel
Yamaha XS850
Triumph Bonneville 650
