That's the first accurate Keihin/Mikuni jet conversion table I've seen - thanks! I have two others I found on the Web; one is somewhat usable, but the other's way off.
Here's some info I found this morning online:
Keihin - OEM main jets - Jets are measured using an unknown convention, in steps of 2 or 3.
Mikuni - Made for Mikuni Carburetors, but will also fit Keihin. Available in 2.5 increments. Mikuni uses yet another measurement convention, reportedly based on flow rate. The result is that Mikuni's sizes are vastly different from the other makers'.
"We are often asked for a "cross reference" sheet that compares our main jets to Mikuni or Keihin. The fact is you cannot directly interchange the jets for a given size. Many things affect fuel flow through a jet of the same orifice size. The entry and exit tapers of our main jets differ from those of other companies. Due to this, the fuel flow changes as a function of velocity through the carburetor venturi. This means that two jets of equal orifice size will have a different fuel flow curve relative to intake air speed. At a certain speed the two may flow equally, but a change in velocity changes the flow characteristics.
The Dynojet main jet hole size is measured in millimeters. For example, a DJ142 has a 1.42mm hole.
Michael Cory
Dynojet Research & Development"
I remember the time I hogged out my CR125's intake for a 36mm Keihin, raised all the ports 1mm, and chopped 4mm off the rear piston skirt. I ended up with a motor that had almost no power below 7,000 rpm.
