Coll,
So you've put a piston-fed boost port in your MR175 cylinder? Cool! Did it make a noticeable difference in performance?
I did some quick measurements on my cylinder and piston a while back and figured it wouldn't have resulted in a high-flow boost port; guess I should have taken more time. I think I measured 15mm from the top of the intake port to the piston crown at BDC and 7mm from the crown to the bottom ring land - does that sound about right? I figured that would leave room for a 6mm high piston window as wide as the cylinder boost-port cutout (maybe 4mm narrower than the space between the ring locator pins). I was also thinking the top edge of the boost port would end maybe 1mm or so below the top edges of the main transfers, leaving them with full crankcase pressure for their initial scavenging blast and reducing mixture loss out the exhaust port when "off the pipe".
I'd love to get measurements and pix when you pull off the head next, but anything you can remember in the meantime would be helpful too - thanks!
I haven't gotten the jetting sorted out yet in the MR175 motor with the correctly-ported cylinder and rev pipe, so I still don't know the full performance potential of the porting specs I posted a while back. The improperly-ported bike is still pulling hard, though.
