It is currently Wed Aug 13, 2025 5:20 am
 Post subject: 1979 cr125r engine case.
PostPosted: Sat Mar 13, 2010 2:39 pm
Is a 1980 cr125r engine case the same case as the 1979 cr125r?
PostPosted: Sat Mar 13, 2010 3:42 pm
i was told by someone on here that the main brg. size is differant. i wonder about trans gears and other engine parts. whats wrong with yours? i needed a case to, mine had sat with water in the bottom of the crank area and ate a hole through the case there. i had it welded but then found a nice one on ebay for the right price. :)
PostPosted: Sat Mar 13, 2010 4:07 pm
Mine has been welded where the swingarm axle goes through. I bought one last night off of ebay from a low mile 1980 that looks really nice for $100. then realized I had the 1 and 0 on the engine number switched around.The 1980 was JE10E and the 1979 was JE01E.
PostPosted: Sat Mar 13, 2010 11:11 pm
if the main brgs. are not the same. i would think a good bearing supply co. could get brgs. that would fit your 79 crank and the 80 case. let use know how you solve this
PostPosted: Sun Mar 14, 2010 7:51 am
this can“t be, cause JE01E is the enginemodelcode for all CR125 from 1979 till now.
PostPosted: Sun Mar 14, 2010 9:40 pm
The 1980 case is made to fit larger diameter main bearings.
PostPosted: Wed Mar 17, 2010 5:26 pm
looks like the seller had a misprint on his ebay add the correct engine number on the 1980 case did start out the same as the 1979 case JEO1E. Thanks for everyones help . I sure hope the main bearing is the only differents.
Users browsing this forum: Google [Bot] and 29 guests
