It is currently Sat Aug 16, 2025 8:55 pm
 Post subject: Carb intake repair
PostPosted: Sat Jun 26, 2004 2:17 pm
:?: Is it possible to repair a cracked carb intake? It's the rubber one that goes between the carb and cyl. It's dry roitted and has a crack that I was wondering if it could be fixed with a tire patch or silicon on the outside so nothing could break loose and go into the engine. Just wondering if anyone had tried anything like this and if it worked :?:
PostPosted: Sat Jun 26, 2004 2:55 pm
I've been wondering this myself. Mine are fine right now, but what will I do when they finally go?
Is the 1980 CR125 carb boot still available?
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Sat Jun 26, 2004 3:44 pm
Mine is a 76 mr250 and they show it on PartsFish but I haven't try to order it to see if they really have one. Besides it's $70!!
 Post subject: Intake issues
PostPosted: Sat Jun 26, 2004 7:25 pm
I have repaired several intakes using a product called "GOOP". It is in the automotive section. Also windshield sealer works well also, something stong and slightly pliable. Give either a try, they work.
PostPosted: Sat Jun 26, 2004 9:43 pm
I use black RTV Sillicone. Put it on, lick your finger and smooth it out. Make it a tad thick if the intake is pretty bad. Keep an eye on it but I got 4 years on a '83 CR60 many years ago.
PostPosted: Tue Jun 29, 2004 3:31 pm
Thanks for the replys. I will give it a try and see how it works. Even if I have to redo it from time to time it may be easier then trying to find a new one.
