montywa wrote:
cool bike! couple more questions.... first, where is the deal on these baskets? That brand is british if i remember. Also, can you give me the scoop on the 300cc setup? There is an expert i race with that has a big bore CR250, i heard he was running an ATC topend. Can you give me the how and what of all that?
THanks
Thanks man, here's a link to the mitaka baskets on ebay UK, they are machined in china designed in UK I believe.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... ink:top:enAs far as the 300cc bigbore topends go if your bike is a centerport 1980 CR250 then you can run the 76mm hondaline ATC300r topend you can tell these kits because of the 7 head studs and straight up fins.
There's also a company called kustom kraft that will take a stock ATC or CR cylinder and re-sleeve it to 76mm here's a link.
http://kustom-kraft.com/hondakits.htmlThen if you want a bigger kit go with a mugen 360 83.5mm I'm sure you guys know about them, I've also found that the fl350 odyssey cylinders line up on the case studs perfectly but like the mugen it requires case boring to slide all the way down, my next drag motor build is using an 85 ATC250r 72mm crank and an 80mm odyssey cylinder to make 380 cc's lol.
