It is currently Thu Jul 24, 2025 8:06 am
 Post subject: Mt250 head shake
PostPosted: Sat Jul 10, 2010 7:40 pm
I was wondering if this was a common problem with these bikes. Its real bad on mine at about 45mph and up whenever it comes on the power as it makes the front wheel very light. It needs to be balanced and is going in tommorow but is there anything I can do besides this, its already been trued so its not that. Lol has anyone ever heard of a dampner on an mt250? I also may have the bearings a tad too loose I need to check that as well.
 Post subject: Re: Mt250 head shake
PostPosted: Mon Jul 12, 2010 7:59 am
I've had my friend's MT250 up to 70mph with no head shake at all. I'd say the front end geometry is more of a street-riding setup, with a lot of rake and slower turning response than an MX bike.
I'd check every single thing in the front end for looseness: steering stem, triple clamps, axle, bearings (wheel and stem), axle spacer, backing plate, etc. I would also check the swingarm pivot as well, for the same things. Problems out back can also cause head shake, especially if it's related to a chassis resonance.
For what it's worth, I always replace all the balls in the steering stem bearings, even if the old ones look OK. The new balls always roll smoothly on the bench, while the old ones often do that clunk-clunk-clunk crap. It would also be a good idea to put in new swingarm bushings, if you can get your pivot bolt out. :)
