It is currently Fri Jul 04, 2025 11:00 pm
PostPosted: Sun Oct 30, 2005 11:32 pm
Re: 76 MT 250:
I want to remove my clutch to check my basket/plates etc. as Prev. Owner did not maintain bike well and clutch won't work.
Which direction do I need to go to remove the nut on the clutch? Lefty Loosey/Rightey Tightey?
Also, would someone please share the crankcase oil capacity for this model.
W.R. :?
PostPosted: Mon Oct 31, 2005 8:33 am
All the clutches I have worked on were standard threads. The nut is normally secured with a tab washer so you will need gently bend the tab back down flat before you try and loosen the nut. I use a Motion Pro clutch holder to hold the basket while undoing the nut. Good luck!
