It is currently Sat Jul 05, 2025 2:49 am
 Post subject: cr250m piston into mt250
PostPosted: Sat Dec 31, 2005 11:53 pm
anyone know if you can use a cr 250m piston in a mt 250?? the piston pin looks the same but the ring pins are not in the same place..
PostPosted: Sun Jan 01, 2006 12:16 am
What year CR piston? I am pretty sure I have CR pistons from 1973-1976 and the rings are thinner in the later models but still in the same place.
All of those interchange with the MT250 from 1974-1976 with only the rings being a problem.
PostPosted: Sun Jan 01, 2006 8:59 pm
the cr piston is 74 and the mt is 74 as well. the cr ring would be a problem???
PostPosted: Sun Jan 01, 2006 10:01 pm
Check carefully.
I think the '75/76 pistons have a slightly relocated ring pin to clear the extra rear cylinder port.
PostPosted: Mon Jan 02, 2006 3:03 am
thanks checked the piston again it was a 75 found the piston out of my 74 and the ring pins are in the same place as the mt only the cr rings are thinner would that be a problem?
PostPosted: Wed Jan 04, 2006 1:40 am
Ring thickness shouldnt worry you so long as you use the correct rings for the piston.ie dont use thin ring in thick piston :oops:
I have both '74 and '75 CR250's.......pistons look the same at first ........but......the '75 has a slightly different ring pin location.( in mine anyway)
I do not know If the MT cylinder changed over the years........if not then I think either piston would work.
The '75CR cylinder gained an aditional rear transfer port which nessitated the slight repositioning of ring pin to prevent ring ends popping into the port.
