It is currently Sat Jul 05, 2025 3:14 pm
 Post subject: cr250m piston into mt250
PostPosted: Sat Dec 31, 2005 11:53 pm
anyone know if you can use a cr 250m piston in a mt 250?? the piston pin looks the same but the ring pins are not in the same place..
PostPosted: Sun Jan 01, 2006 12:16 am
What year CR piston? I am pretty sure I have CR pistons from 1973-1976 and the rings are thinner in the later models but still in the same place.
All of those interchange with the MT250 from 1974-1976 with only the rings being a problem.
PostPosted: Sun Jan 01, 2006 8:59 pm
the cr piston is 74 and the mt is 74 as well. the cr ring would be a problem???
PostPosted: Sun Jan 01, 2006 10:01 pm
Check carefully.
I think the '75/76 pistons have a slightly relocated ring pin to clear the extra rear cylinder port.
PostPosted: Mon Jan 02, 2006 3:03 am
thanks checked the piston again it was a 75 found the piston out of my 74 and the ring pins are in the same place as the mt only the cr rings are thinner would that be a problem?
PostPosted: Wed Jan 04, 2006 1:40 am
Ring thickness shouldnt worry you so long as you use the correct rings for the piston.ie dont use thin ring in thick piston :oops:
I have both '74 and '75 CR250's.......pistons look the same at first ........but......the '75 has a slightly different ring pin location.( in mine anyway)
I do not know If the MT cylinder changed over the years........if not then I think either piston would work.
The '75CR cylinder gained an aditional rear transfer port which nessitated the slight repositioning of ring pin to prevent ring ends popping into the port.
Users browsing this forum: Google [Bot] and 35 guests
