It is currently Sat Aug 16, 2025 3:42 pm
PostPosted: Mon Aug 01, 2011 1:55 pm
Hi guys what is the actual proper weight of oil a guy should use in the transmission of a 78 cr250? In hot climate...
Thanks in advance...
PostPosted: Mon Aug 01, 2011 5:32 pm
i´m using ATF for about 20 years now at all 2T trannies.
PostPosted: Mon Aug 01, 2011 10:32 pm
SAE 80w motorcycle gear oil.
PostPosted: Tue Aug 02, 2011 6:26 pm
haha ok you guys are at totally different ends of the rainbow here!!! One is using ATF the other is using 80W gear oil?? I have been using straight 30W but was thinking of switching... maybe i should hold a poll of what everyone else uses.... not whats 'proper'....
PostPosted: Wed Aug 03, 2011 9:15 am
no, :wink: both are gearoils.
ATF is special designed for gears and clutches.
one advantage is perfect clutchwork when oil is cold.
you can also use 10w-40 (or for hot climate 20w-50) MOTORCYCLE engine oil.
choose what you prefer.
don´t use truck or car gear oil.
PostPosted: Wed Aug 03, 2011 5:17 pm
Ok I was thinking 80w automotive differential oil when i read it, and I always thought atf was way too thin but hey if you guys use it then obviously its not!! I will likely try the 20w50. Thanks
PostPosted: Wed Aug 03, 2011 5:48 pm
Also... Iv always just guessed on the amount but whats the proper amount to put in?
PostPosted: Thu Aug 04, 2011 8:37 am
PostPosted: Thu Aug 04, 2011 8:47 am
.... I always thought atf was way too thin ...
that´s the advantage, you need less power to turn the transmission with the thinner oil.
PostPosted: Thu Aug 04, 2011 11:42 am
Would a guy notice a difference in power if he switched to atf or is that unlikely? Also I never knew about the oil check bolt... i always just looked through the filler hole and guessed... cool... are all bikes like this or just the red racers?
