It is currently Mon Aug 11, 2025 5:53 am
PostPosted: Thu Jul 28, 2011 1:36 am
With no real luck finding any OEM intake manifolds for the early CR cyls, I discovered that for the price of the aftermarket versions that Mossbarger did a reed valve kit... but i cant get hold of them to find out more as the email addy is dead and i cant phone the USA from here. So anyone used these or have an idea on how to contact them via email?
PostPosted: Fri Jul 29, 2011 12:12 pm
I had one and once the jetting was right it was fine you do have to make your own airbox though as it put's the carb a lot further back
PostPosted: Sat Jul 30, 2011 5:43 pm
Thanks for the heads up. Looks like with the CR engine in the MT frame I am going to have to lose the airbox and run a pod filter or something i fab myself anyway, but getting too close to the rear wheel might be an issue.
PostPosted: Sun Aug 07, 2011 11:22 am
Jon, if you plan on putting the Mossbarger on your MT/CR hybrid, you will need to do quite extensive frame mods as the spine/hoop under the MT's seat, goes down much further than the CR's and you will struggle to fit a carb. It is quite a big job that I am underway with on my MT/CR hybrid. It has meant major frame surgery but I'm nearly there now.
I will be using a Twin Air filter that has a rubber boot bonded to it and fabricating an air box to go around it.
I have tried to get in touch with Mossbarger and like you, no replies.
I recently bought another CR250M Mossbarger reed assembly for a project that I'm not sure I'll have the time to do so if you are intent on going down this route, I may possibly have one for sale - complete with Mossbarger's additional piston and barrel modification instruction sheet for maximum performance.
Another option is to buy a YZ250A reed valve and carb inlet manifold and then machine / fabricate a manifold to bolt the reed valve to the cylinder.
I believe this is the mod Don Jones did to Gary's championship winning CR250...
Wish I had that knowledge before going down the route of modifying my frame.
Just a few thoughts for you.
Grae.
PostPosted: Mon Aug 08, 2011 8:25 pm
Grae, thank you so much for the info! I think you may have just saved me from a whole lot of hard work... but i may well revisit this idea on my other bike... feel free to PM me if you want to sell your spare kit, I may be interested... im a glutton for punishment perhaps!
Im also interested to hear about the YZ conversion, sounds like that might bring the carb lower and may save some headaches... all good ideas...
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
