It is currently Sat Aug 16, 2025 8:22 pm
 Post subject: o-ring size
PostPosted: Fri Sep 30, 2011 5:58 pm
anybody know the diameter of the o-rings that hold on the front # plate 79 cr250 I just got original plate but need o-rings I had an after market plate on front but do not like the mounting of it
 Post subject: Re: o-ring size
PostPosted: Wed Oct 05, 2011 9:47 am
Find an appliance repair shop and check out their supply of sewing machine drive belts and/or vacuum cleaner belts. I personally found the latter to thick / strong and they deformed the mounting tabs. The former work OK but have a shorter lifespan. BTW, you can use the same source for the rubber band that pinches the side panels to the air box.
