It is currently Thu Jun 19, 2025 2:35 pm
 Post subject: MT250 Base Jets
PostPosted: Fri Sep 28, 2012 12:30 pm
I have a November 1974 MT250 and the throttle response is less than good. Now that I have rebuilt two MR175s, I think I should expect a little more from my MT250. It putters on the idle to 1/2 throttle and does not snap to or snap back when the throttle is revved. I want to check the jetting to see if anything has been changed by the previous owners. I checked the timing with a timing light and it appears to be pretty close to the mark.
Does anyone have the standard jetting for me to compare?
 Post subject: Re: MT250 Base Jets
PostPosted: Fri Sep 28, 2012 3:58 pm
122 main jet, 60 pilot, 3.0 throttle slide, 271002 needle.
PostPosted: Fri Sep 28, 2012 10:50 pm
To save you a ton of time and tail chasing, change the needle jet. Mine was worn, and it would not idle and was uncontrollably pig rich below 1/2 throttle. I changed the needle jet out for one from my parts carb, and it is far better. New ones are available, but only from a supplier in the UK for 25 Euros plus shipping.
I am working on putting a Mikuni on mine, since I have a torn boot anyways. I am having to make a new mount for it, but that's easy.
PostPosted: Sat Sep 29, 2012 7:47 am
I wanted to check to see what was original first, because I know at least one "carb kit" was used on it and I don't know what jets were replaced. It had it bored one over and never changed anything, so I figured I would start with the baseline before making any jettting changes. Any suggestions on what I should expect to change in an overbore?
Any reason for going with the mikuni? I have one of those sitting around too.
PostPosted: Sat Sep 29, 2012 11:20 pm
I'm going with the Mikuni for three reasons: It's larger, parts are more readily available, and I am more familiar with them. As a plus, they do seem to respond to tuning better than the Keihins.
I found a carb mount to go to a tube, so I'm having a flange cut, then just weld a tube to it and clamp everything together. I still haven't decided if I will put an oil port on it or run pre-mix. There's a lot of hills around here, so I may stick with injection.
PostPosted: Thu Oct 25, 2012 5:56 pm
I'm wanting to put a Mikuni on mine also i am sick of messing with the Keihin. What size of carb are you using? Any jetting recommendations yet?
Users browsing this forum: No registered users and 49 guests
