It is currently Thu Jun 19, 2025 3:39 pm
PostPosted: Mon Oct 08, 2012 6:59 pm
Seem to have alot of wiggle in my counter sprocket after install, sprocket looks fine, probably alot of wear on the shaft. I really dont want to split the case and replace the shaft at this point, unless my crank seals are bad. Anyone ever delt with this?
PostPosted: Wed Oct 17, 2012 1:21 pm
Honda drive sprockets, the ones with the two screws and retaining ring, are designed to move a bit. Unless your shaft splines are very worn, this is not a problem.
dean (Honda mechanic in the 70's)
PostPosted: Wed Oct 17, 2012 7:09 pm
Thanks alot for the reply
PostPosted: Sat Oct 20, 2012 1:09 pm
Honda drive sprockets... are designed to move a bit.
But not too much. I ran into the same problem when restoring my
73 CR250. The first test fit with a good, but used CS sprocket
produced quite a bit of slop. I found a NOS CS sprocket and that
reduced the slop a little. Then I found a NOS countershaft and
now it's a nice tight fit with no movement.
IMO, the culprit here is the countershaft itself and the two bolt design.
The two bolt design allows a rider to keep using a worn out CS sprocket
which, in turn, eventually wears out the countershaft due to the poor
strength of the alloy Honda used though out the transmission.
I recommend you purchase a repro or NOS CS sprocket and put it away
in case you're ever lucky enough to find a NOS countershaft.
In the mean time, that little bit of slop will get bigger and bigger every
time you put the bike in gear and experience that driveline snatch.
PostPosted: Sat Oct 20, 2012 8:38 pm
thanks alot for the info!
