It is currently Thu Jun 19, 2025 5:37 am
 Post subject: Mulholland Rear Shocks
PostPosted: Sat Mar 23, 2013 10:14 pm
Hello Elsie Fans,
I'm in the process of restoring my 1976 CR250M and had removed the rear shock spring on my Mulholland shock, and was about to break loose the rod guide when it broke, these are really nice vintage shocks and would like to save them, any Elsie Budddies out the know wher I can get the Aluminum threaded hex rod guide for my shocks, also will need the rebuild seals, hope someone can lead me in the right direction so I can save these babies, thanks for any help in keeping my Elsie Alive and vintage.
PostPosted: Sun Mar 24, 2013 9:24 am
Post a pic of what you broke and Ill see what I have.
You can also try Rick @ Vintage Iron
http://www.vintageiron.com
PostPosted: Tue Mar 26, 2013 5:55 pm
Here are some pictures of my rear Mulholland Shock you can see in picture the hex nut that threads into shock body is craked in half, believe it is called the rod guide, it is hex with a slot cut through it, my shocks measure about 15-1/4" eye to eye center. needing hex rod guide and lead for rebuild seal kit. any help in saving these would be greatly appreciated and help in my restore of my Elsie, many thanks again.
Mike Warren (The Dog ) Raced Elsie's from 1976 to 1980
Users browsing this forum: Google [Bot] and 20 guests
