Ive watched some of the vids on youtube and one guy was wacking the crank with a hammer to remove it....NICE
NEVER do that use a case spreader tool
See this guide:
http://www.dirtrider.com/features/two-stroke-rebuildAnother tip is once the case is free of the main bearing on the igniton side it is ready for you to pull apart the rest of the way. Use left hand fingers to pull on the case and humb pushing on crank and other hand fingers to pull on the case and the thumb pushing on the countershaft while pulling the case apart, this way the trans will stay in the ignition side case and not fall all over the floor. Be sure to look at the newly removed case side for any shims that may have stuck to the bearing from oil tension. Put a zip ty on the trans shaft ends to keep everything sano while you have them out or some of the gears will fall off.
In the pics from the link the crank should have stayed in the clutch side of the case, the puller you use will push on the crank to push it out of the ignition side case. ALSO when you assemble the crank back into the cases sometimes there is a shim on the clutch side of the crank, sometimes not but the crank MUST bottom onto the clutch side of the case bearing, usually the main dive gear nut will do this.
Ultimately you want the crank and trans, shift drum, shafts to stay in the clutch side case.
The only real stumper youll have is putting the transmission, shift drum, shift forks and shafts back into the clutch side case, that is a tough deal sometines, just take your time and try to hold the shift drum/forks/shaft in one hand and the transmission shafts in the other holding them together as a unit then ease them into the trans cavity trans shafts first once everything is in the general area you can use a soft mallet to tap the trans shafts into their bearings along with the shift drum and shift shafts. It takes some finesse to do it properly so dont get bummed if you have to do it several times to get it right.
Like I said in the other post and as you can see in the link you need to build a wooden box tall enough to hold the engine on its side and up off the bench, this way the clutch transmission shaft has all kinds of room and isnt pivoting on the bench. Youll see how tall you need to make the box once you get the clutch off the clutch shaft.
Once you do this a couple of times youll be doing all your friends cases.
Good luck
