It is currently Thu Jul 17, 2025 6:05 am
PostPosted: Fri Jul 12, 2013 6:05 pm
I almost completed my '74 CR125M restauration, but I have problems to make it running fine.
When I try to start it, I put the choke on and it start after only 2 kicks. But it run only for 5 second and die. I kick it again 2 or 3 times, and it does the same thing all the time.
I did a complete engine rebuild. New bearings, new seals, new oversized piston and rings.
The carburator was completely clogged. I did a soda blast and a complete cleaning.
I didn't found the basic setup for the carb. How many turn the fuel screw (slow jet)? For the air screw, they said to start at 1 1/2 turn, I did the same with the fuel screw, 1 1/2. The jet needle, it was at the second groove. I tried at the third also.
The rubber boots are hard, It look ok but I wonder if it can suck air? But I can't try to spray some cleaner to see if it affect the running since it doesn't run for more than 5 seconds every time.
I looked at the spark plug and it look a little bit wet.
Any idea of what can cause this kind of problem?
PostPosted: Sat Jul 13, 2013 4:41 am
You put the choke on, start the bike, then immediately turn the choke off and it runs for 5 seconds? Or is the choke on for 5 seconds (too long)? Does this bike have the original carb, with '005A' stamped on the body behind the choke?
Can you start the bike without the choke, maybe by push-starting it?
Try running the air screw at 2 or 2.5 turns out for now. The idle speed screw (large one on left side) is adjusted to get the idle speed you want - there's no fuel screw on this carb. 1.5 turns on the speed screw isn't even close; I believe mine's turned in over 6 turns. Try backing out the speed screw completely, then turn it in 5.5 turns and start the bike, and if it still only runs for a short time, turn the speed screw in another 1/2 turn and try again.
Jetting for the original '74 carb is 125 main, 60 pilot, 200 air, and 3.5 throttle valve.
PostPosted: Sat Jul 13, 2013 11:34 am
Rayivers, you're the man!!!
Yes, this is the original carb, 005A. And also yes, when I tried to start it, I let the choke on. I didn't remember that from 40 years ago! :lol:
So I did the adjustment you wrote, put the choke on, start it, put the choke off and gived a little bit of throttle, and it worked!!!
I will now have to adjust the idle once warm and it will be very good I think!
Thanks a lot Rayivers!
PostPosted: Sat Jul 13, 2013 1:55 pm
No problem - I'm glad it worked!
