MR175 crank rebuilds are kind of a nightmare, as the rods are practically nonexistant (if the rod feels sloppy surely its big end surface is at least partially to blame, although a new bearing and crankpin might improve things a lot). My friend is presently working with Crank Works to see if it's possible to hone the rod end for an oversize bearing and/or pin, or use an early RD350 rod, which I believe is 1mm longer ctr-ctr but otherwise very similar. It's actually easier to find a NOS MR175 crank than a rod.
Here are the bearing substitutions I have; the KA3 and KS3 parts are for the '81-'83 CR125R. Some are still available OEM:
91004-373-006 / 91004-373-300 / 91004-KA3-003 / 91004-KA3-004 / 91004-KS3-901 91005-373-006 / 91005-KA3-003 / 91005-KA3-004 / 91005-KS3-901 91006-373-006 / 91006-373-300 / 91006-KA3-003 / 91006-KA3-004
I've managed to find all three crankpins, using eBay and Google.
13381-373-300 / 13381-373-310 (2 groove) 13382-373-300 (1 groove) 13383-373-300 (no groove)
_________________ '74 CR125M (175cc), '75 MR175, '82 RM250Z, '08 YZ250F, '14 Zero FX electric, '14 Zero MX electric, '18 Alta MXR electric
