It is currently Wed Jun 18, 2025 11:33 pm
PostPosted: Tue Nov 05, 2013 7:48 pm
Hi guys , Does anyone know if the 300 top end kit for the 250r is anywhere near compatible for a 1979 cr250 ?? If the cylinder bolt pattern is close the rest should be doable. Anyone ever seen the 300 kit for the atc ??
PostPosted: Sun Nov 10, 2013 5:47 am
http://www.hondapartshouse.com/oemparts/a/hon/506f8aeaf8700229747b9484/atc300r-kit
this kit was made by mugen as the 360 kit.
i´ve seen a used one on ebay some years ago priced a bit higher than a 360 kit and imidiately sold.
in a 79 frame you will get a problem with the outlet. it´s straight as the 80 cr.
