1979 CR125 shift issue - Just fired up the CR125 for the first time. rode it up/down the driveway in 1st. Went to try 2nd and I find that the shifter seems to be ``locked up``. When I did the bottom end everything was fine and it shifts 1-6 & back no problem. Now that I have it running, only 1st & neutral.
Further investigation shows that the selector arm lateral movement of around 1/4 inch. When it is all the way ``out`` it won`t shift. But if held ``in`` it shifts fine. My dumb question is if there is a missing clip or spacer on the selector arm for a 1979 CR125R?
Further investigation:
OK, the diagram shows a small collar that is on the selector arm, that is between the arm on the wet side and the outer case. Looks to be about 1/4 inch, which is the amount of in/out play that I have. Part number is 24620-444-000
Found the collar, NOS, from a supplier down south.
Well I installed the collar (it was missing) and that took up the slack (side to side) movement. Put in fresh oil and ran it thru the gears. Seemed a bit funky, but did shift.
Primed it and fired it up. 1st gear no problem, neutral and then it won't go any higher under power.
So I'm thinking it could be a bent shift fork or the shift drum is bad. Anybody else have this problem? Looks to be a total lower end tear down and maybe a transmission. Did want to ask before doing this. With the number of cobbled fixes I have found on this one, it wouldn't be too surprising to find more missing/bent/broken things.
