It is currently Wed Aug 06, 2025 7:42 am
PostPosted: Thu Sep 11, 2014 7:55 pm
Apologize for a REALLY stupid question, but, here goes. Purchased a set of rear blinker stems from a E-bay member and I cannot figure out how they attach! The blinker stems came with a 6mm screw that protrudes on one side of an oval shaped chrome base and then there is the hollow tube with knurling to attach the body of the blinker housing to. No threads on the hollow tubing that the wires pass thru. How in the world does this attach given there are no threads of sorts attached to the frame? There are no recesses on the oval shaped mount to slip Inside a oval shaped hole on the bike frame. I would be more than happy to supply a picture tomorrow morning of the posts and frame portion of the mount if you think that would help. Take a peak at your's to see what you might find if you'd be so kind. I would GREATLY appreciate it.
UPDATE: It looks like I would need both a #10 and a #12 in the following schematic. A couple #11's would be nice too:
http://www.partzilla.com/parts/search/H ... parts.html
Any out there to purchase?
Thanks!
PostPosted: Sat Sep 13, 2014 7:14 am
Yes you will need those items plus the small collars the screw goes through. I eventually found the rubber insert and had to make a mount patterned from the one I had.
The old Honda cb models used the same blinker stems.
For some reason those mounting brackets are hard to find. I guess people threw them away once the blinkers were removed.
PostPosted: Sun Sep 28, 2014 7:08 pm
I must have gotton extremely lucky. I found a pair of brackets with the rubber inserts on fleabay. If the light enclosures, which would be all four, front and rear, arrive thiis week, I should have blinkers installed this weekend if all goes well. It's coming around rather well for a 38 year old bike!
Users browsing this forum: No registered users and 10 guests
