It is currently Tue Jul 01, 2025 4:42 pm
PostPosted: Mon Jan 26, 2004 6:57 am
What brands of oil do you guys use on your 78/79 cr250 and what ratio's do you mix them with gas?
Thanks,
Dave Anderson
PostPosted: Mon Jan 26, 2004 6:58 am
Golden Spectro @ 32:1. The same stuff I used way back then when I ran every weekend. The main is also kicked up 2 sizes to pass the heavier oil concentration. Only use if the top end and crank are tight. Rings were replaced quartly, piston every 6 months during that time period from 78 to 82. One of my original cylinders is currently being used by a Mid-Atlantic rider now.
I run Maxim at 40:1 in my 73-83 cr250's and I've never had a problem with it. It doesn't have that great smell of Klotz Benol but it doesn't generate carbon buildup either. Good stuff.
PostPosted: Mon Jan 26, 2004 6:59 am
el-Ray MC-1 at 50:1
PostPosted: Mon Jan 26, 2004 7:00 am
Yep, MC-1 50:1 (or even 60:1) in everything. You can dump your extra race gas in your weedwacker!
lso put honda 2 stroke sythetic oil 32:1
Users browsing this forum: Google [Bot] and 39 guests
