It is currently Thu Jun 19, 2025 4:01 am
 Post subject: not pulling under load
PostPosted: Sun Aug 30, 2015 4:46 am
Hi all,
Just rebuilt my 2nd 78 cr125 starts first or second kick revs cleanly right through but put it in gear just doesn't want to pull. Any info welcome, had someone said my carb is to small its curently has a 28mm kehin would a 33mm make a difference.
Malcolm
PostPosted: Sat Sep 05, 2015 5:54 am
Well the answer is no it's another problem! But still open to suggestions from those in the know!
PostPosted: Fri Sep 11, 2015 5:34 am
I would use the carb it was designed for with a thorough rebuild.
PostPosted: Tue Nov 03, 2015 4:06 am
Only getting 85-90p.s.i. reading on compression test suspect piston & cylinder!!!.............................. on last bore Suzuki piston in it?
Anybody got a cylinder and piston preferably on 1st bore.
PostPosted: Sat Nov 14, 2015 5:29 am
Hi all couple a pics
PostPosted: Tue Dec 15, 2015 6:46 pm
Clean bike.
Consider a new sleeve instead of used cyclinder. Hard to find one with decent life on it anymore.
Rick
PostPosted: Thu Jan 21, 2016 4:10 pm
So folks, latest update........it was the cylinder. got one on first bore very very clean, std piston all within tolerances. Sand blasted, new paint job, new gaskets then put it all back together, comp test @ 150 p.s.i carb on original jet sizes according to the manual.............f*****g hell!!! :shock: goes like s**t of a shovel. :D
Pics will follow.
PostPosted: Fri Jan 22, 2016 6:52 am
Good to hear! Lets see those pics.
PostPosted: Sun Jan 24, 2016 8:24 am
Hi folks, here are a couple of pics.
PostPosted: Sun Jan 24, 2016 8:33 am
And the other (without light kit)
PostPosted: Sun Jan 24, 2016 11:21 am
Both bikes look great!
Users browsing this forum: No registered users and 47 guests
