It is currently Tue Jun 17, 2025 11:09 pm
 Post subject: 79 CR125 front hub
PostPosted: Tue Dec 13, 2016 8:42 am
Wanting to switch to a 21" front wheel. I have some 16.5" remote res Ohlins to lower the rear.
Could i relace the 79 125 hub with 78-80 250 spokes and matching rim? Is the 1980 125 hub and brake panel the same as the 1979?
Thanks, Brad
 Post subject: Re: 79 CR125 front hub
PostPosted: Fri Dec 16, 2016 1:09 pm
Yes 1980 CR125 the same as is the 78 - 80 CR250
PostPosted: Fri Dec 16, 2016 11:08 pm
Thanks. Is the 79 125 hub the same as well?
PostPosted: Sun Jan 22, 2017 10:41 pm
79-81 CR125's use the same part # front hub. You would need a spoke set from an 80-81.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 30 guests
