It is currently Sat Aug 16, 2025 12:33 am
PostPosted: Thu Dec 15, 2016 9:33 am
Hi I have a 1974 mt125 engine that I have put on a 1974 cr125 frame. The cr frame still has its oringinal magneto and the electrical box thing. The mt stator and flywheel don't seem to be working so I was wondering if I could put a cr flywheel and stator? Thank you
PostPosted: Thu Dec 15, 2016 2:57 pm
As long as the MT and CR crank keyways are in exactly the same position, it should work. The '74 CR rotor is designed to be held on with a bolt and not a nut like the MT flywheel, but the nut should work fine with a washer underneath it.
