It is currently Sun Aug 17, 2025 10:08 pm
PostPosted: Mon Jan 03, 2005 11:35 am
how much do i put in? how much? and will 30 wt oil work good in them?
PostPosted: Mon Jan 03, 2005 11:38 am
I would be surprised if you want to use anything heavier than ATF or 10-weight...
PostPosted: Mon Jan 03, 2005 10:46 pm
how much do i put in? 4 oz?
PostPosted: Mon Jan 03, 2005 11:11 pm
Sorry I just don't know, you will have to hope someone with the 125 speaks up. (The figures for a CR250R 1979 are 205 cc if you pump the forks out, and 275 cc if you re-fill them dry.)
PostPosted: Tue Jan 04, 2005 4:32 pm
Hey Gomer,
If you drained the fork tubes only, you'll need to replace it with 9.6oz or 285cc of oil in each leg. Now if you completely torn them down and cleaned them and they are dry, you'll need to refill it with 10ozs or 295cc of oil in each leg. Okay now they came with 5W fork oil in them, so 10W is okay, but I would not advise on 30W unless you weighed 460 lbs, and in that case I would suggest a CR480. ThatÃŒs what I use to get my big ass around the track. I hope this helped? :mrgreen:
Don Brooks
Vintage Elsinores
Ventura, CA.
http://www.elsinores.com
PostPosted: Tue Jan 04, 2005 5:29 pm
Don, what fork and shock setup are you running on the CR480R? I am 180lbs before the gear goes on and my fat ass is round the front. :D
PostPosted: Wed Jan 05, 2005 7:43 pm
ok guys this is wat i did... i put 8oz of 30wt oil in eat leg and its perfect! i weight 220 pounds and do some pretty hard trail riding.. so thats that
PostPosted: Wed Jan 05, 2005 11:18 pm
30 wt hydraulic oil?
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Thu Jan 06, 2005 12:22 am
i dont know.. all i know is its fork oil from the dealer
PostPosted: Thu Jan 06, 2005 9:19 pm
BEL-RAY maybe?
Don Brooks
Vintage Elsinores
Ventura, CA.
PostPosted: Thu Jan 06, 2005 10:32 pm
no its some chineese name like sinkoline or soemthing like that
PostPosted: Fri Jan 07, 2005 11:51 am
Silkolene maybe? :shock:
PostPosted: Fri Jan 07, 2005 5:39 pm
Last time I checked Silkolene was pretty good oil, and I wouldn't refer to it as cheesy? :shock: :mrgreen:
Don Brooks
Vintage Elsinores
Ventura, CA.
PostPosted: Fri Jan 07, 2005 10:45 pm
yea i got it from the honda dealer :lol:
