It is currently Tue Jun 17, 2025 11:14 pm
 Post subject: '74 MT 250 Carb Setting
PostPosted: Tue Aug 08, 2017 12:45 pm
I have a question regarding my newly rebuilt '74 MT 250 and it's carb setting. Took it out for my first ride and found when reaching 4500 rpm or so the engine stops accelerating and starts running rough. It's been 40 or more years since I worked on a two stroke so not clear if I'm running into a rich or lean situation? Any thoughts?
Thank-you,
Kevin
'74 MT 250
2010 Honda Gold Wing
2009 Kawasaki Concours 1400
PostPosted: Thu Aug 10, 2017 7:02 pm
Hello Kevin,
I have a '74 MT250 on it's first overbore;it runs well with the needle clip in the bottom groove. I found this by trial and error because Canadian model carb specs seem to be quite different from U.S.
Be sure that the 6 holes in the endplate of the muffler upstream of the removable spark arrestor are clear and unplugged or performance will be anemic whatever the carb settings.
PostPosted: Thu Aug 10, 2017 8:15 pm
So a bit of an update.
I purchased a new spark plug, the dealer didn't have the exact NGK plug but had the resistor type plug. Come to find out they don't work well in an older vehicles such as the MT as they need more voltage to function. Switched to the non-resistor (the correct plug) and the bike runs much better at higher rpm but still has the same but less of a problem between 4 & 5K rpm. The plug looks good maybe a little on the dark side.
Not clear if I have a timing problem or point gap or ? Going to bring it to someone and see what he can find in a few weeks. In the mean time I'll look at where the clip is placed and maybe experiment with that first.
Kevin
'74 MT 250
PostPosted: Mon Aug 14, 2017 10:35 pm
Update #2
Moved the carb slide needle jet clip to the bottom cutout, that actually made it run worse. So moved the clip to the top setting, now I have ok low end power and smooth performance between 4000 and 5500 rpm then gets rough.
But something still needs tweaking as the power band is very uneven and lacks the punch it should have.
Kevin
'74 MT 250
PostPosted: Tue Apr 17, 2018 10:24 pm
i have a question do you or any body out in elsinore land know :? were to get a new carb to air box rubber boot for
a 74 mt 250
any info would be greatly apreciated
PostPosted: Thu Apr 19, 2018 8:18 pm
a 74 mt 250
Not sure you'll find a new boot but here's the Honda p/n 17214-358-000.
It's possible I have an extra, I'll check and get back to you.
Kevin
'74 MT 250
PostPosted: Fri Apr 27, 2018 7:29 pm
a 74 mt 250
I have a used carb to air box boot for a '74, let me know if you want it.
Kevin
'74 MT 250
PostPosted: Tue May 01, 2018 6:23 am
I'm having the same problem with mine, is your oil injection still connected?
73 Honda CR250m
74 Honda CR250m
75 Honda CR250m1
76 Honda CR250m1
80 Honda CR250R
79 Yamaha YZ250F
79 Yamaha YZ400F
74 Yamaha GTMX80
75 Honda MT250 x3
66 Honda CA77 305 Dream x2
67 Honda CB77 305 Super Hawk
2009 Yamaha YZ250 2-smoker
2008 Honda CRF150RB
PostPosted: Tue May 01, 2018 12:02 pm
Yes, I am using the oil injection system. Please see the thread titled Carb Components for help setting the carb and purchasing the correct spark plug. Ray has a wealth of knowledge on this subject as you will see. Let me know if I can help, good luck.
Kevin
'74 MT 250
PostPosted: Sat Aug 04, 2018 3:54 pm
a 74 mt 250
These are now available:https://www.ebay.com/itm/Reproduct-air-boot-for-MT250-Elsinore-VMX-vintage-motocross/253747025613?hash=item3b148056cd%3Ag%3AJikAAOSwru9bFMre&_sacat=0&_nkw=mt250+air+boot&_from=R40&rt=nc&_trksid=m570.l1313
Ebay item number 253747025613
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 27 guests
