It is currently Fri Jul 04, 2025 10:32 pm
PostPosted: Wed May 04, 2005 4:34 pm
so my elsinore's been sittin' up for the winter. went to start it and i've got no spark to the plug or the plug wire. but i DO have pulsing power to the black/white wire that goes into the ignition coil as i kick the bike. anybody know what's goin on?
Lee
~1974 honda elsinore MT250
~1974 honda cb750 chopper
~1988 jeep grand wagoneer
~1978 pontiac firebird
PostPosted: Thu May 05, 2005 8:13 am
I'd bet points for the first round of things to look at. Sounds like they may not be making contact. Never hurts to hit them with a points file or emory board anyway.
PostPosted: Wed May 11, 2005 1:34 am
If you are talking about your MT 250 Elsinore, and you are getting a pulsing signal to the coil primary from the Black/White wire, I suspect you may have a stuffed capacitor (condensor). This happens sometimes when the bike has been sitting around in damp conditions for a period of time.
Anyway it's a good starting point as capacitors are cheap.
If that fails to start your rocket, check the continuity of the primary and secondry circuits of the coil.
There isn't a lot more that can go wrong with these babes.
As a final thought! - I don't know if MT 250's have a kill switch. If yours does, there may be a short killing the voltage to the coil, but I suspect not as you say you are getting a pulse to the coil.
Best of luck - and let us know how you get on
cheers
Ray :wink:
