It is currently Wed Jun 18, 2025 2:16 am
PostPosted: Sun Jan 20, 2019 3:32 pm
Does anyone have information on what type of flywheel; puller is used on the left side under the stator to remove the small flywheel?
PostPosted: Thu Jan 31, 2019 10:12 am
I believe it is a 16 mm bolt with metric thread that you just screw into the original flywheel. Make sure that the end of the bolt does not hit against the flywheel at the bottom of the flywheel threaded hole. I let the flywheel retainer bolt in place of course after having loosened it a few turns to enable the flywheel to come off.
PostPosted: Sat Feb 16, 2019 3:35 pm
